Value – The input color or texture node. Input Min – Specifies the lower range or the minimum value for the input map. Input Max – Specifies the higher threshold or the maximum value for the input map. Output Min – Specifies the minimum value for the output map. Output Max – Specifies the maximum value for the output map. |
