V-Ray Node Space offers a number of nodes arranged in the following categories: Color, Distribution, Generator, Material, Math, Surface and Utility. V-Ray offers two output (Colored Node) nodes - Material and Two Sided Material. Each Node system holds only one output (Colored) node. Some of the nodes are texture nodes used as utility or surface maps. V-Ray Node space is available in Cinema 4D versions 21.1 and later! |
