Value – The value to multiply the texture with. Texture – An input slot to connect the texture to. Mix Strength – A multiplier for the connected texture - blends between the value and the texture. Texture Clamp – When enabled, the output is clamped to 1 from above (always clamped to 0 from below). Result Multiplier – Specifies a multiplier for the end result. |
