This page provides reference information for Chaos Player text fields.
Starting with Chaos Player 1.0.4, the text in text layers may contain embedded fields of the form {object:property}. Such fields are replaced with their values before the text is displayed. To disable expansion of a specific field, double the {character; for example, to insert the literal text {clock:date}, use {{clock:date}.
The field object (the part before the colon) can be "composition", "timeline", "clock", "mask", a single layer, or a layer set.
In addition, the formatting code can be altered with the # flag.
The composition object supports a single property:
{composition:name} | composition name such as "fields.pdpcomp" |
The timeline object supports the following properties:
{timeline:frame} | current frame |
{timeline:frame+2} | current frame plus 2 |
{timeline:frame-1} | current frame minus 1 |
{timeline:frame,4} | current frame, padded with zeros to length 4 |
{timeline:frame-1,4} | current frame minus 1, padded to length 4 |
{timeline:timecode} | current frame, converted to timecode using the current frames per second |
{timeline:timecode+584} | current frame plus 584, as timecode |
{timeline:timecode/30} | current frame as timecode using 30 fps |
{timeline:timecode/29.97} | current frame as drop frame NTSC timecode |
{timeline:timecode+85521/24} | current frame +85521 using 24 fps |
The clock object supports the following properties:
{clock:date} | current date (in local, short form) |
{clock:longdate} | current date in local long form |
{clock:time} | current time |
{clock:%Y-%m-%d} | current date, in year-month-day form |
{clock:%d.%m.%Y} | current date, in day.month.year form |
{clock:%H:%M:%S} | current time, in 24hr hour:minute:second form |
The clock object supports a format string as property. In the string, the following format codes are replaced as described:
%a | Abbreviated weekday name |
%A | Full weekday name |
%b | Abbreviated month name |
%B | Full month name |
%c | Date and time representation appropriate for locale |
%d | Day of month as decimal number (01 – 31) |
%H | Hour in 24-hour format (00 – 23) |
%I | Hour in 12-hour format (01 – 12) |
%j | Day of year as decimal number (001 – 366) |
%m | Month as decimal number (01 – 12) |
%M | Minute as decimal number (00 – 59) |
%p | Current locale's A.M./P.M. indicator for 12-hour clock |
%S | Second as decimal number (00 – 59) |
%U | Week of year as decimal number, with Sunday as first day of week (00 – 53) |
%w | Weekday as decimal number (0 – 6; Sunday is 0) |
%W | Week of year as decimal number, with Monday as first day of week (00 – 53) |
%x | Date representation for current locale |
%X | Time representation for current locale |
%y | Year without century, as decimal number (00 – 99) |
%Y | Year with century, as decimal number |
%z, %Z | Either the time-zone name or time zone abbreviation, depending on registry settings; no characters if time zone is unknown |
%% | Percent sign |
The mask object supports the following properties:
{mask:width} | current mask width |
{mask:height} | current mask height |
A layer can be identified by index or by name. A positive index identifies a layer starting from the top of the layer stack, and a negative number - from the bottom. So, for example, {1:name} refers to the name of the first layer, and {-1:name} refers to the name of the last layer (first from bottom). A layer can be identified by name by enclosing the name in single quotes, as in {'######.dpx':path}. The layer after '######.dpx' can be identified with {'######.dpx'+1:path}, and other offsets also work.
A layer supports the following properties:
{1:name} | layer name |
{1:width} | layer width |
{1:height} | layer height |
{1:length} | layer length in frames |
{1:timecode} | embedded timecode, from file header |
{1:edgecode} | embedded edgecode, from file header |
{1:keycode} | same as edgecode |
The following three fields support offset and width as described for {timeline:frame}.
{1:frame} | layer frame, zero-based |
{1:fnframe} | frame from file name |
{1:emframe} | embedded frame, from file header |
{1:path} | path to current frame |
The path property can be indexed to select a single path element or a sequence of elements:
{1:path[1]} | selects the first element of the path |
{1:path[2]} | selects the second element of the path |
{1:path[-1]} | selects the last element of the path (the file name) |
{1:path[1..3]} | selects first three elements |
{1:path[1..-2]} | selects from the first to the second to last (that is, everything but the file name) |
Suppose that {1:path} is "D:\footage\000186_10\557568.dpx". Then,
{1:path[1]} | is "D:\" |
{1:path[2]} | is "footage\" |
{1:path[3]} | is "000186_10\" |
{1:path[4]} | is "557568.dpx" |
{1:path[5]} | is "" |
{1:path[-1]} | is "557568.dpx" |
{1:path[-2]} | is "000186_10\" |
{1:path[-3]} | is "footage\" |
{1:path[-4]} | is "D:\" |
{1:path[-5]} | is "" |
{1:path[1..2]} | is "D:\footage\" |
{1:path[-2..-1]} | is "000186_10\557568.dpx" |
The layer properties can also be used with a set of layers. In this case, the field is replaced with the properties of the layers in the set, separated with new lines. So, for example, {1,2,3:name}, where the names of the first three layers are "Layer 1", "Layer 2" and "Layer 3", is replaced by:
Layer 1
Layer 2
Layer 3
A layer set can have the following forms:
selection, -selection – Identifies the currently selected layers. -selection is the same, but in reverse order.
{selection:name}. |
group(K), -group(K) – Identifies the layers having group ID of K. -group is in reverse order.
{-group(4):timecode}. |
* layer..layer – Identifies several consecutive layers, where "layer" in the above represents a single layer identified by index or name, as in the previous section.
{1..5:name}, {1..-1:name}, {'Adjustment 1'+1..-1:name}. |
set,set,...,set – Combines several layer sets of the previous forms.
{1..2,5,8..-1:name}, {group(1),group(2):path}. |
set!set – Takes the first set and discards all layers in the second. If the first set is not present, takes all layers as the first set. Examples: {!group(1):name} - the names of all layers that are not in group 1, {group(2)!1..5:name} - the names of all layers in group 2 that are not among the first five. An additional syntax, {set::property}, can be used to scan 'set' for the first layer for which the current time falls within the in:out points. 'property' is then taken from that layer. This is useful when several clips are arranged one after another. As an example, if the last three layers in the stack are such sequentially arranged clips, {-3..-1::timecode} and {-1..-3::timecode} will both select the timecode of the current clip. The difference between the two is that the first will scan from top to bottom, and the second will scan in reverse order. This may be significant if the layers overlap.
The # flag may prefix any formatting code. In that case, the meaning of the format code is changed as follows.
%#a, %#A, %#b, %#B, %#p, %#X, %#z, %#Z, %#% | # flag is ignored. |
%#c | Long date and time representation, appropriate for current locale. For example: "Tuesday, March 14, 1995, 12:41:29". |
%#x | Long date representation, appropriate to current locale. For example: "Tuesday, March 14, 1995". |
%#d, %#H, %#I, %#j, %#m, %#M, %#S, %#U, %#w, %#W, %#y, %#Y | Remove leading zeros (if any). |
