This page provides information on VRayDecal.
This example shows the effect of several decals applied onto a caravan object.
The Normal angle is set to 40 degrees. The first image shows the decal effect without a Fade out angle. The second render has Fade out angle enabled and set to 120 degrees. Note how the effect is enclosed between the Normal and Fade out angles.
This example shows the effect of decal displacement.
This example shows the effect of decal displacement. Use only decal displacement is turned on in the second image.
The video show you how to project decals on cylinder-like objects and blending surface details.
