Filter Source – Selects what type of messages to show in the V-Ray Log Window. The render process should start at least once in order to appear in the Filter Source list. Show All – Shows all type of messages - both NeUI and V-Ray. NeUI Main – Shows messages related to NeUI only. V-Ray – Shows V-Ray plugin related messages. Asset Manager – Shows messages related to Asset Manager only. Remote Logging Service – Shows messages coming from Rhino only. Assets Preview Renderer – Shows messages related to the Asset Editor's preview renderer. Filter Level – Specifies whether to show all messages, only errors and warnings or only errors. Wrap – Wraps the text. Search bar – Allows you to search in the log by a keyword. The Go To Log File ( ) button opens the log file directory. The Clear Log ( ) button clears the V-Ray Log Window from the current messages. Using the Clear Log button with a specific source filtered clears only its log. Select the Show All option to clear everything. The Clear Log button only clears the V-Ray Log Window, the actual log text file is preserved. |
