Please make sure that your system fulfills these requirements before installing V-Ray. For additional information on hardware, see the Hardware Recommendations article.
Processor | Intel 64, AMD64 or compatible processor with SSE4.2 support |
RAM | 8 GB RAM and 8 GB swap minimum – recommended 16 GB or more RAM. |
Hard Disk Space | Minimum 2GB, Recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported. |
Supported GPU | Maxwell-, Pascal-, Turing-, Volta- and Ampere- based NVIDIA card(s) with the latest recommended video driver (for both CUDA and RTX - enabled cards) V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities |
The following table shows the versions of Rhinoceros 3D and the operating systems on which V-Ray is supported. Note that V-Ray is only supported for 64-bit operating systems and 64-bit versions of Rhino.
Version of Rhino | Supported Operating System |
Rhino 6 (v6.34.21034 or later) | Windows 8.1 and Windows 10 Professional |
Rhino 7 (7.6.21127 or later) | Windows 8.1 and Windows 10 Professional |
Customer support is available only for V-Ray 5 and V-Ray Next (V-Ray 4). Earlier versions are no longer supported. |
