Navigation Move speed – Specifies the speed at which the camera moves. The value is in meters per second. Eye height – Sets the eye height for the camera in meters when in Free look() mode and Collisions() enabled. Basic Resolution Preset – Resolution preset allowing you to choose the resolution. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. Focal length/Field of view – Specifies the equivalent focal length or field of view value of the camera lens. Listed parameter depends on the Lens Mode setting in the advance options. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. Exposure value/Film speed(ISO) – Specifies the exposure value or ISO of the camera. Listed parameter depends on the Exposure setting in the advance options. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. White balance – Allows additional modification of the image to compensate for the "color temperature" of a light source, which refers to the relative warmth or coolness of white light. Objects in the scene that have the specified color will appear white in the image. White balance will only work when Exposure is set to either Physical or Value. When Exposure is None, White balance will be disabled. |
Depth of field – Enables the depth of field effect. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. Automatic vertical tilt correction – When enabled, sets and preserves vertical lines to be parallel, simulating 2-point perspective. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. Camera clipping – When enabled, turns on the camera clipping. Press the () button to open the advanced options window. Press again the () button to close the advanced options window. Create New Camera – Saves the current camera view to a new camera slot. (Shortcut: Ctrl+K ) Save (Overwrite) () – Overrides the current camera slot with the current camera view. (Shortcut: Ctrl+Shift+K ) Delete ()– Deletes the camera slot. It has to be clicked twice. You can switch between the camera slots using the Home and F1-F12 keyboard keys. |
