This page provides information on the V-Ray UVWGenBercon node.
The V-Ray UVWGenBercon node is a V-Ray implementation of a UV coordinates generator for Bercon texture maps.
Features such as driving the parameters (e.g. Distortion) of one Bercon Noise texture by using another's output will not work as expected unless this specific UV mapping VOP is connected as the "uvwgen" input.
UI path:
||mat Network|| > V-Ray > Texture: Mapping > V-Ray UV Bercon
Mapping Type –  Controls how the procedural texture is mapped. Giving a choice between Explicit Map Channel 2D, Explicit Map Channel Real WorldObject XYZWorld XYZ, and Screen.
Transform Offset – Controls the offset of the generated noise.
Transform Size – Controls the transform size of the procedural noise.
Transform Angle – Controls the transform angle of the procedural noise.
Tile – Controls the transform tiling of the procedural noise. You can select to either Continue, Stretch, Tile, Mirror or deselect (None) the way the texture pattern appears along the corresponding axis.
Variance Offset – Adds a transform offset variation to the generated noise.
Variance Size – Controls the variance size of the procedural noise.
Variance Angle – Controls the variance angle of the procedural noise.
Seed – An integer used as a starting point for the random generator. Different values produce different noise randomly.
Random by Material – Randomizes the variance value based on material ID, when the texture is connected to more than one material.
Random by Object – Randomizes the variance value based on the object ID.
Random by Particle – Randomizes the variance value based on the particle ID.
2D Mode
Camera Space – Enables calculations in camera space.
