MainZ Order – Specifies a layering order when multiple V-Ray Decal gizmos are present. The decal with the larger Z Order value is set on top of the other ones. In case of equal Z Order values, the bounding boxes of the decals are taken into account for positioning. Size – Size multiplier for the V-Ray Decal box. Projection Offset (%) – Specifies the offset of the V-Ray Decal gizmo in percentages. This parameter can take values below 0 and above 100. Normal Angle – Specifies the angle to which the decal is applied onto the surface below. Enable Fading by Normal Angle – Enables the use of a fade out angle. Fade Angle – Specifies the angle which creates a fadeout gradient starting from the Normal Angle. Values closer to the Normal Angle produce a sharper gradient. The maximum fade out angle is 180 and it can't take values less than the Normal Angle. See the Fade Angle example for more information. Bend – Specifies the bend angle for the V-Ray Decal in degrees when placed on a curved surface. ShadingProject on Back Side – Enables the visibility of the projected image on the back side of the face. This option is useful for objects without an actual thickness where the back side of the polygons is exposed to the viewer. Material – Specifies a material to project over the geometry in the scene. No Material Color – Specifies the color of the decal when no material is assigned to it. Mask Texture – Masks the projected material based on a texture. The material must be applied to the V-Ray Decal. Resize for Mask Texture – Sets aspect ratio from mask file. BumpUse Only Decal Bump – When enabled, the original surface bump isn't taken into account. Surface Bump Amount – Specifies the percentage of the surface bump that affects the V-Ray Decal. DisplacementDisplacement Texture – Specifies a texture to evaluate for the displacement. See the Decal Displacement example for more information. Displacement Amount – Specifies the amount of displacement applied. A value of 0.0 means the object appears unchanged. Higher values produce a greater displacement effect. A negative value can also be entered, in which case the displacement pushes geometry inside the object. Displacement Shift – Specifies a constant which is added to the displacement map values, shifting the displaced surface up and down along the normals. This can either be a positive or negative value. Use Only Decal Displacement – When enabled, the original surface displacement is not taken into account. See the Use Only Decal Displacement example for more information. Affected ObjectsExclude Mode – Specifies the effect of the Exclude list. Exclude – Objects in the Exclude list are not affected by the decal. Include – Only objects in the list are affected by the decal. Exclude – Specifies an include/exclude list that allows you to select which scene objects to be affected by the V-Ray Decal. |
