Render to Disk – Starts a V-Ray render. Controls – Launches the Houdini Render Control window. Valid Frame Range – Specifies the frame(s) to render. Render Current Frame – Renders the current frame. Render Frame Range – Renders frames from the specified range set below as well as other frames if they are referenced by in-range frames. Render Frame Range Only (Strict) – Only renders the frames in the specified range set below. Start/End/Inc – Specifies the range of frames to render (start frame, end frame, and increment). Render with Take – Renders using the settings from a specified take. Output AUR File – A path to the output .aur file. Storage Quality – Storage quality of the output .aur (lowest means max compression, highest means lossless). |
