Introducing Chaos Player
Fast-forward your digital review workflow with Chaos Player, a professional image sequence player designed for fast and smooth playback.
Review your own or your team’s animation output in playback right after the rendering finishes. See new and updated frames instantly. Chaos Player is also powered up for basic compositing, color grading, and editing in real-time — even while playback is running. And much more.
Features
Playback image sequencesPlayback high-resolution image sequences quickly and efficiently with Chaos Player’s smart caching system. New and updated frames load instantly. |
Layer sequencesLayer multiple sequences for simultaneous playback. By stacking layers, you can composite, edit and cut, tech check, and more. |
A/B Wipe CompareCompare up to four versions of a shot in playback. Swipe and zoom into the details to tech-check and perfect your own and other people’s work. |
Export to MP4Export your cuts, edits, and compositions to MP4 videos or choose from a variety of image formats. |
CompositeComposite layers quickly and easily in real-time while playback is running. Export to Adobe After Effects or Foundry’s Nuke for final output. |
Adjust colorsQuickly and easily fine-tune exposure, contrast, color balance, and layer blending modes in real-time while playback is running. |
Edit and cutQuickly arrange your shots, cut sequences, or add animated fade effects. |
Broadcast and collaborateShare previews of your animations on a HTTP server or directly on a broadcast monitor. Share ideas with your team by adding text and brush annotations. |
Key and grade on setKey, composite, and grade live on set and in real time. |
Command line supportSeamlessly integrate Chaos Player into your pipeline with extensive command-line support. |
