Enable – Enables the rendering of the channels included in this render elements group. – Adds additional render elements to the render elements group. – Deletes all the render elements in the render elements group. Active – Enables the render of the current channel. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. Consider for AA – By default, the Image sampler applies AA based on the RGB image. When this option is enabled, the Render Element is considered for AA. Filtering – When enabled, it applies the antialiasing filter to the render element. Color Mapping – Applies the default color mapping options to this render element (Reinhard). Group By – Specifies how the scene lights will be listed in VFB. Individual Lights – Lighting information of each light is stored in a separate channel. Manual Light Select – Render channels are created based on the existing Light Select render elements in the scene. Lights that are not specified there, are collected in single render channel called Rest. |
