This allows you to search for materials. Note that if a Revit Identity Class name is inputted in the search bar, only the materials belonging to that class are displayed in the list below. You can also choose from the following options in the Filter drop-down menu: Show MaterialsAll – Allows you to choose from all materials in your library (includes defaults and materials in the project). Used in project – Allows you to choose from all materials in your current Project. Latest Render – Shows a list of all materials that were exported by V-Ray during the latest render you have done. Prism only – Shows a list of all Prism materials, i.e. all materials that can be promoted using the Promote Revit materials as V-Ray ones functionality. V-Ray MappingAll – Allows you to see all materials in your library (includes defaults and materials in the project). Mapped – Allows you to see all materials that have been assigned a V-Ray Material. Unmapped – Allows you to see all materials that have not been assigned a V-Ray Material yet. TransparencyAll – Allows you to see all materials, i.e. the Transparency filter is not applied. Opaque – Allows you to see only the opaque materials in the project. Transparent – Allows you to see only the transparent materials in the project. Opaque and Transparent filters can be used as an alternative to the Global Overrides options, with the ability to exclude specific materials from the override. |
V-Ray Grass/FurAll – Allows you to see all materials, i.e. the V-Ray Grass/Fur filter is not applied. Mapped – Allows you to see all materials that have been assigned a V-Ray Grass/Fur. Unmapped – Allows you to see all materials that have not been assigned a V-Ray Grass/Fur. Fur assigned to a material can be disabled from the Fur ( ) icon in the Appearance Manager when the material is selected. A grey dot next to a material indicates that Fur is assigned to that material. |
V-Ray DisplacementAll – Allows you to see all materials, i.e. the V-Ray Displacement filter is not applied. Mapped – Allows you to see all materials that have been assigned a V-Ray Displacement. Unmapped – Allows you to see all materials that have not been assigned a V-Ray Displacement. Displacement assigned to a material can be disabled from the Displacement ( ) icon in the Appearance Manager when the material is selected. A grey dot next to a material indicates that Displacement is assigned to that material. |
Right-click on the filter icon, resets the filters to their defaults. When you click on the Pick Material button ( ), and select a surface in the Revit model, you can see only its material displayed in the material list. Note that the option works only on surfaces that are native for the Revit model and does not work for linked models. |
