Some options are available only in Advanced mode. Front Material – Sets the material to be used for front faces as defined by the object normals. Back Material – Sets the material to be used for back side faces as defined by the object normals. Translucency – Determines which side (front or back) relative to the camera is more visible in the rendering process. By default this color is black (0.0), which means that only the front side is visible. When set closer to white (1.0), more of the Back material is seen. When set closer to black (0.0), more of the Front material is seen. Mult. By Front Diffuse – When enabled, the Translucency is multiplied by the Front material. Force Single Sided – When enabled, the sub-materials renders as one-sided materials.Disabling is not recommended.
Can be Overridden – When enabled, the material can be overridden when you enable the Opaque override option in the Global Overrides tab of App.Man. |
