This page provides information about the supported .vrscene features exported from V-Ray for Revit.
 Chaos Vantage has better support for .vrscene files exported from V-Ray Next, V-Ray 5.
Lights
Native name
V-Ray plugin name
Support
POINT
SphericalLightSphere(tick)
HemisphericalLightRectangle(error)
SpotLightSpotMax(tick)
IESLightIESMax(tick)
LINE
SphericalLightRectangle(tick)
HemisphericalLightRectangle(tick)
SpotLightRectangle(tick)
RECTANGLE
CIRCLE
(tick)
(tick)
Camera
UINative nameV-Ray plugin nameSupport
 V-Ray CameraCameraPhysical
Mode:
Standard
VR Spherical Panorama
VR Cubemap
SettingsCamera/type=0
SettingsCamera/type=9
SettingsCamera/type=10
(tick)
(error)
(error)
Stereo:
Side-by-side
Top-bottom
 RenderView/stereo_on
(error)
(error)
(error)
Exposure (EV)combination of ISO, f_number, shutter_speed(tick)
Exposure (EV) AutoSettingsCamera/auto_exposure
(error)
White Balancewhite_balance(tick)
White Balance AutoSettingsCamera/auto_white_balance
(error)
Focus Source:
Fixed Distance
Fixed Point
(minus)
(minus)
Focus Distancefocus_distance(tick)
Defocuscombination of ISO, f_number(tick)
Vignettingvignetting(error)
Geometry
Native NameV-Ray Plugin NameSupport
V-Ray DisplacementGeomDisplacedMesh
(error)
V-Ray Fur
GeomHair
(error)
V-Ray Proxy
GeomMeshFile
(tick)
V-Ray SceneVRayScene
(error)
Materials
Bump
BRDFBump
  • Bump
  • Map
Car Paint
BRDFCarPaint
  • Base color
  • Base reflection
  • Base glossiness
  • Coat color
  • Coat strength
  • Coat glossiness
HairBRDFHair3(error)
BlendBRDFLayered
  • Base material
Emissive
BRDFLight
(tick)
VRscan
BRDFScanned
(error)
Subsurface Scattering
BRDFSSS2Complex
Scatter Color is not supported
GenericBRDFVRayMtl(tick)
PBRBRDFVRayMtl(tick)
Two Sided
Mtl2Sided
(error)
OverrideMtlOverride(error)
Toon Material
MtlToon
(error)
Two SidedMtl2Sided
  • Front Material
  • Back Material
  • Translucency
WrapperMtlWrapper(error)
The table below lists the AutoGen materials (native Revit materials automatically converted to V-Ray ones).
LayeredBRDFLayered
(error)
GlazingBRDFVRayMtl(tick)
MetalBRDFVRayMtl(tick)
OpaqueBRDFVRayMtl(tick)
TransparentBRDFVRayMtl(tick)
VRayMtl
UINative nameV-Ray plugin Name (plugin/parameter)Support
GenericBRDFVRayMtl
Diffuse Colordiffuse(tick)
Diffuse Color Texturediffuse(tick)
Diffuse Roughnessroughness(error)
Diffuse Roughness Textureroughness(error)
Reflection Colorreflect(tick)
Reflection Color Texturereflect(tick)
Reflection Glossinessreflect_glossiness(tick)
Reflection Glossiness Texturereflect_glossiness(tick)
Fresnelfresnel(tick)
Reflection IORfresnel_ior(tick)
Reflection IOR Texturefresnel_ior(tick)
Metalnessmetalness(tick)
Metalness Texturemetalness(tick)
GGX Tail Falloffgtr_gamma(error)
Surface Control:
Use Glossiness
Use Roughness
option_use_roughness=0
option_use_roughness=1
(tick)
(tick)
BRDF Type:
Phong
Blinn
Ward
Microfacet GTR (GGX)
brdf_type=0
 brdf_type=1
 brdf_type=2
 brdf_type=4
(tick)
(tick)
(tick)
(tick)
Back Side Reflectoption_reflect_on_back
(tick)
Max Depthreflect_depth(error)
Affect Channels:
Color only
Color+alpha
All Channels
reflect_affect_alpha=0
reflect_affect_alpha=1
reflect_affect_alpha=2
(error)
(error)
(error)
Trace Reflectionsreflect_trace
(error)
Anisotropy(-1 to 1)anisotropy(error)
Anisotropy Textureanisotropy(error)
Rotationanisotropy_rotation(error)
Rotation Textureanisotropy_rotation(error)
Derivation:
Local axis
Map channel
anisotropy_derivation=0
anisotropy_derivation=1
(error)
(error)
Local Axis:
Y
Z
anisotropy_axis=0
anisotropy_axis=1
anisotropy_axis=2
(error)
(error)
(error)
Map Channel/Setanisotropy_uvwgen
Dim Distance enabledreflect_dim_distance_on(error)
Dim Distancereflect_dim_distance(error)
Dim Falloffreflect_dim_distance_falloff(error)
Refraction Colorrefract(tick)
Refraction Color Texturerefract(tick)
Fog Colorfog_color
(tick)
Fog Color Texturefog_color(error)
Fog Multiplierfog_mult
(tick)
Fog Biasfog_bias
(tick)
IORrefract_ior(tick)
IOR Texturerefract_ior(tick)
Refraction Glossinessrefract_glossiness(error)
Refraction Glossiness Texturerefract_glossiness(error)
Affect Shadowsrefract_affect_shadows(tick)
Fog Units Scalingfog_unit_scale_on(error)
Max depthrefract_depth(error)
Affect Channels:
Color only
Color+alpha
All Channels
refract_affect_alpha=0
refract_affect_alpha=1
refract_affect_alpha=2
(error)
(error)
(error)
Trace Refractionsrefract_trace
(error)
Dispersiondispersion_on(error)
Abbedispersion(error)
Fog Scatteringtranslucency(error)
Type:
Hard (wax) model
Hybrid
Back-side Color
Scatter Coeff
Thickness
Light Multiplier
translucency=1
translucency=3
translucency_color
translucency_scatter_coeff
translucency_thickness
translucency_light_mult
(error)
(error)
(error)
(error)
(error)
(error)
Back-side Colortranslucency_color(error)
Back-side Color Texturetranslucency_color(error)
Scatter Coefftranslucency_scatter_coeff(error)
Fwd/back Coefftranslucency_scatter_dir(error)
Thicknesstranslucency_thickness(error)
Light Multipliertranslucency_light_mult(error)
Coat Amountcoat_amount(tick)
Coat Amount Texturecoat_amount(tick)
Coat Colorcoat_color(tick)
Coat Color Texturecoat_color(tick)
Coat Glossinesscoat_glossiness(tick)
Coat Glossiness Texturecoat_glossiness(tick)
Coat IORcoat_ior(tick)
Coat IOR Texturecoat_ior(tick)
Coat Bump Enabledcoat_bump_lock(tick)
Coat Bump Mode:
Bump Map
Bump Texture Channel
Normal Map
coat_bump_type=0
coat_bump_type=5
coat_bump_type=1
(error)
(error)
(error)
Coat Bump Map Texturecoat_bump_map
(error)
Coat Bump Amountcoat_bump_amount(error)
Coat Bump Amount Texturecoat_bump_amount(error)
Sheen Colorsheen_color(error)
Sheen Color Texturesheen_color(error)
Sheen Glossinesssheen_glossiness(error)
Sheen Glossiness Texturesheen_glossiness(error)
Opacityopacity
(error)
Opacity Textureopacity
(tick) 1
Custom Source:
DIffuse Texture Alpha
Opacity Texture Alpha
opacity/TexCombineFloat
opacity/TexAColorChannel/mode=3
(tick)
(error)
Mode:
Normal
Clip
Stochastic
opacity_mode=0
opacity_mode=1
opacity_mode=2
(error)
(tick) 1
(error)
Bump Mode:
Bump Map
Normal Map
bump_type=0
bump_type=1
(tick)
(error)
Bump Map Texturebump_map
(tick)
Bump Amountbump_amount
(tick)
Bump Amount Texturebump_amount
(error)
Mode:
Multiply
Blend amount
TexCombineColor/color
TexCombineColor/texture_multiplier
(tick)
(tick)
Colordiffuse/TexCombineColor/texture_multiplier
(tick)
Reflection Colorreflect/TexCombineColor/texture_multiplier
(tick)
Reflection Glossinessreflect_glossiness/TexCombineColor/texture_multiplier
(tick)
Refraction Colorrefract/TexCombineColor/texture_multiplier
(tick)
IORrefract_ior/TexCombineColor/texture_multiplier
(tick)
Refraction Glossinessrefract_glossiness/TexCombineColor/texture_multiplier
(error)
Opacityopacity/TexCombineColor/texture_multiplier
(error)
EmissiveBRDFLight
Colorcolor(tick)
Color Texturecolor(tick)
IntensitycolorMultiplier(tick)
Intensity TexturecolorMultiplier(tick)
Transparencytransparency(error)
Transparency Texturetransparency(error)
Emit On Back SidedoubleSided(error)
Compensate EVcompensateExposure(error)
Color*OpacitymultiplyByOpacity(error)
Mode:
Multiply
Blend amount
(tick)
(tick)
ColorTexCombineColor(tick)
IntensityTexCombineColor(tick)
TransparencyTexCombineColor(error)
 BumpBRDFBump
Basebase_brdf(tick)
Map:
Bump Map
Normal Map
bump_tex_color
map_type=0
map_type=5
map_type=1
(tick)
(tick)
(tick)
(error)
Normal Map Type:
Tangent Space
Object Space
Screen Space
World Space
map_type=1
map_type=2
map_type=3
map_type=4
(error)
(error)
(error)
(error)
Amountbump_tex_mult_tex(error)
Delta Scalebump_delta_scale(error)
Maps
UINative nameV-Ray Plugin NameSupport
BitmapTexBitmap(tick)
ColorTexAColor(tick)
TemperatureTexTemperature(error)
GradientTexRamp(tick)
Color CorrectionColorCorrection(tick)
Spline CurveTexRemap(tick)
Bezier CurveTexBezierCurveColor(tick)
Simple MixTexCombineColor(tick)
Mix (Value)TexBlend(tick)
Mix (Operator)TexCompMax(tick)
Mix (Map)TexMix(tick)
Multi-Sub (tick)
Tri-PlanarTexTriPlanar(tick)
CheckerTexChecker(tick)
GridTexGrid(tick)
TilesTexTiles(tick)
ClothTexCloth(tick)
LeatherTexLeather(tick)
BulgeTexBulge(tick)
UVWTexUVW(tick)
WaterTexWater(error)
Noise ATexNoise(tick)
Noise BTexNoiseMax(tick)
CellularTexCellular(tick)
MarbleTexMarble(tick)
SplatTexSplat(tick)
SmokeTexSmoke(tick)
StuccoTexStucco(tick)
RockTexRock(tick)
GraniteTexGranite(tick)
SpeckleTexSpeckle(tick)
EdgesTexEdges(error)
FalloffTexFalloff(tick)
FresnelTexFresnel(tick)
CurvatureTexCurvature(error)
DirtTexDirt(error)
Geometry
RevitSupport
Revit families replaced with .vrmesh(tick)
Native Revit RPCs will render as grey planes(error)
Revit families replaced with a .vrscene(error)
Infinite Ground Plane(error)
Fur(error)
Displacement(error)
