This page provides information about the V-Ray Renderable Spline tag in Cinema 4D.
VRayRenderableSpline tag allows V-Ray to render splines. Splines can also be assigned with texture maps.
A temporary limitation is that only the U size is renderable.
Splines with VRayRenerableSpline tag are visible in the following render channels: Light, Raw Light, Total Light, Raw Total Light, Normal Map and Bump Normal Map.
