This render element is enabled through the Render Elements tab of the Render Setup window in 3ds Max and displays its parameters in a rollout at the bottom of the window: VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer. Deep output – Specifies whether to include this render element in deep images. Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier. Denoise – Specifies whether to denoise this render element. Add background – When enabled, adds the background to the render element. |
