Export – Specifies which objects from the scene to be included in the exported proxy. All Objects Selected Selected Including Children Add Proxy to Scene – When enabled, creates proxy objects for the exported meshes. The proxies will have the correct transformations and materials derived from the original objects. The original objects will be deleted. Remove Exported Objects – Elements per Voxel – Specifies the maximum number of faces in a voxel after voxel subdivision. Preview Type – Specifies the method for producing a preview mesh from the original geometry. Face Sampling Clustering Edge Collapse Combined Preview Faces – Specifies how many faces are going to be used to show a preview of the proxy in the viewport.
Animation Animation Range – Specifies an animation range to be exported to the .vrmesh file. Current Frame Use Render Settings Custom Start Frame/End Frame – Specifies a frame range to export. Frame Rate – Specifies a frame rate at which the animation is exported. |
