Create procedural animations for Active Bodies with a directable Thruster Force.
Restrict Active Bodies to move or rotate along a selected horizontal or vertical axis using the Axis Lock.
Extra control over how Active Bodies interact with your scene — choose whether they should emit, attract, and retain fluids, and much more.
Create realistic effects quickly and easily with new and enhanced presets.
Create more realistic foam, faster. Easily add variety to the size and look of your patterns.
Shade fire and smoke simulations, and meshes in a single simulator using the Voxel Shader — giving you more time to be creative.
Speed up your simulations with the initial implementation of the Phoenix Standalone Simulator and easily debug your scenes through the Phoenix simscene Node Editor.
Phoenix for Maya now runs on macOS.
New 'Size Variation' and 'Stringy' options for the Foam Pattern shapes, allowing for more diverse and interesting patterns
Multithreaded the routine where moving obstacles push the FLIP particles
'Burn Smoke RGB' color option for coloring the smoke created by fuel burning
Pick Active Bodies as emitters in Sources, as attractors in Body Force, in 'Distance To' fields in Tuner Expressions, as Birth Volumes and Render Cutters
New Thruster node for the Active Bodies, allowing you to propel an active body in a certain direction, which can also be attached to the body so it changes direction as the body rotates
New Axis Constraint node for the Active Bodies, allowing you to block the movement of the active body in a certain direction, or to also stop the active body from rotating around a certain axis
New option in the Active Body Solver to use the Simulator's jammed walls as obstacles for Active Bodies
Added an 'Affect by Foam' option to the Active Body Solver that controls how strongly the Foam pushes the Active Bodies - by default it is off
Use Cosmos assets as Active Bodies (latest V-Ray 5 is needed)
New separate Voxel Shader node, allowing shading of both fire/smoke and meshes from the loaded data of the same Simulator without having to duplicate the Simulator
Option to flatten particles near the Liquid Simulator's borders in Ocean Mesh mode, like the vertices of the ocean do
PRT cache import straight into the Simulator and the Standalone Preview, without the need for a PRT Reader node. This also allows retiming of PRT sequences
New "phoenixfd" command-line executable that simulates .simscene files exported from 3ds Max, similar to V-Ray Standalone. It simulates up to 40% faster than inside 3ds Max or Maya. Currently it only supports Simulator and Source nodes, as well as Phoenix node properties. Still to be added are: Foam/Splash options, support for animated options and animated geometries, resimulation, textures
Phoenix FD menu option to Export, Simulate and simultaneously launch the Standalone Preview application to observe the simulation result
Added a Phoenix Node Viewer application for exploring the node graph of .simscene files. Dragging and dropping would also display .vrscene files
Mesh Preview, including wireframe mode, customizable via the command line
Viscosity Voxel Preview
Smoke Opacity modulated or replaced by textures will show in the viewport GPU Preview
Reduce or increase grid resolution with the cache_converter tool
Simulation Restore button in the Phoenix toolbar
New 'Jet Engine' and 'Stormy Sea' quick setup toolbar presets
New 'Ice Cubes' and 'Speedboat' quick setup toolbar presets
macOS support and notarized Phoenix app bundle
Support for Maya 2023
Windows 11 support for NUMA machines. Windows Vista is no longer supported after this change and the minimum supported version is Windows 7
Sped up fire/smoke simulations with up to 20%
Multi-threaded the Adaptive Grid of fire/smoke simulations when Preallocation is On
Repeatedly increase the resolution using resimulation that overwrites the same cache sequence
FLIP resimulation now writes caches to new "_resim" files instead of overwriting the old ones
Sped up and improved thread balance of liquid simulations with moving obstacles
Improved Foam 'B2B Interaction' and Splash 'Liquid-Like' that don't shoot particles away and can now be used even with Ocean setups
Allowed values below 1 for the 'Mist Amount' option and excluded it from affecting how fast Splash particles are deleted
Made the default Foam 'Half Life' 10 like in 3ds Max
Ocean Simulations with Adaptive Grid can now expand upwards without the ocean level changing
Sped up simulations with enabled Motion Inertia that don't actually move
Allowed rendering with V-Ray GPU while the CPU simulation is running in both IPR and production modes. With V-Ray CPU, the simulation is paused during rendering
New model for calculating buoyancy of Active Bodies, allowing better interaction with the Wave Force in large scale ocean vessel setups
'Collider Type' option in the Node Properties, allowing choice between fast or precise collision options
Reduced the required V-Ray GPU memory when rendering fire/smoke volumes
Sped up render start with thousands of simulator copies
Fall back to Bubble mode when rendering with V-Ray GPU in Point mode
Sped up 2x frame blending with Time Bend controls
Updated OpenVDB from version 5 to version 8.1
Sparsify VDBs exported by the Phoenix simulation or the Cache Converter so now they are generally smaller
Recognize by default Velocity(x), Velocity(y) and Velocity(z) channels from VDBs from thinkingParticles
Show the sizes on storage of the different data chunks in AUR files in the Standalone Preview and Cache Converter
The Phoenix installer now associates the Phoenix Previewer as default program for opening AUR, VDB, F3D and PRT files
Drag & drop AUR, VDB, F3D and PRT caches in the Phoenix Previewer
'Auto Load Latest' option that monitors the storage for newly appearing sequence files
Right click menu over the loaded cache directory for copying the full path or just the file name
'Log Verbosity' option in the Phoenix Preferences that has these levels: Debug, Info, Important, Warnings and Errors. Low res simulations can be 10% faster in 'Important' compared to 'Debug'
Faster and better looking Fire quick setup toolbar preset
Increased the brightness of the Cold Smoke quick setup toolbar preset
Increased the height and tweaked the colors of the Candle quick setup toolbar preset
Use just one Particle Shader for all emitters in the Ink in Water quick setup toolbar preset, and shade using the new 'Color From Particle RGB Channel' option
Improved the simulation and rendering of the Ocean toolbar quick setup preset and made it more like the Ship example scene
Allowed selecting channels that are not available in the entire cache sequence in the Color From Particle Channel box
Affect Temperature, Smoke and Fuel separately by turning off the new 'Affect All Fire/Smoke Channels' option
Create a set if it does not exist when opening the Sets Editor from the Particle Shader, Particle Texture, Source and Simulator Interaction
Renamed the 'Droplet Breakup' option to 'Droplet Formation' in order to be more clear what the option does
Renamed the 'B2B Interaction' option to 'Foam Volume' in order to be more clear what the option does
Show a warning saying that Foam on Hit Resimulation requires Splashes to be resimulated
The installer no longer places vray_phoenix, field3dio_phx, openvdbio_phx and distance_measurer_phx in V-Ray's plugins directory; Instead it appends the VRAY_FOR_MAYAXXXX_PLUGINS environment variable
Dropped support for Maya 2018
Dropped CentOS 6 support for V-Ray Next
Hid the 'Backtrace (Classic)' Advection Method from the user interface
Initial Liquid Fill produced wetmap over submerged Solid geometry even when there were no liquid particles nearby
Wetmap didn't fully cover objects submerged in liquid created by a Volume Brush Source
Volume Inject Liquid Sources created more particles in voxels partially overlapped by the emitter or by Solid obstacles
The Variation Large option of the Foam was not working, since Phoenix 4.40
Foam Birth Amount differed from 3ds Max. Now it's in particles per cubic centimeter
The Viscosity Diffusion effect changed drastically between 1 and 0.999
Non-Solid liquid emitters in Surface Force mode with disabled Motion Velocity contributed negative velocity
Adaptive Grid crashed when a fire/smoke simulation expanded over 2.1 billion voxels
Rare crash when resimulating with Adaptive Grid with Preallocation
Rare crash if the simulation interacted with another Simulator
Changing the grid resolution affected Volume Inject discharge of liquids (scenes saved with older Phoenix versions might simulate differently after this fix)
Volume Inject mode for liquids emitted much less pressure than 3ds Max when units were set to meters
Particles used as emitters kept adding velocity when Motion Velocity was Off but there were discharge modifiers in the Source
Volume Brush created liquid, foam and splash particles with a gap around submerged objects, compared to Initial Liquid Fill
Discharge modifiers in Object space were not correct when the emitter was another Simulator
The Motion Velocity in the Extra Phoenix Attributes of nParticles used in a Source was ignored
Liquid resimulation broke Active Bodies simulation
Moving Active Bodies in Maya killed many FLIP particles, unlike in 3ds Max
Active Bodies may freeze in scenes with large meter scale
Restoring a simulation with Active Bodies caused them to jump to the scene origin for a frame
Sometimes a feedback loop accelerated Active Bodies through the liquid
Explosive velocities were created when using a static liquid Simulator as a Volume Brush emitter
Some Out of memory situations when interacting with scene geometries or particles were not handled and lead to a crash
Geometries with scale of 0% created huge velocities in the simulation
Crash on simulation start with some large VRayProxies
Buckets in the Shadow, Raw Shadow, GI, Raw GI, Light Select and Lighting render elements of a Simulator with Volume Light Cache
Crash when Denoiser was used with a Simulator with the Volumetric ZDepth option set to 'Standard Element'
Noise with Fire simulation and reflective material with Glossy below 1
Render artifacts using Probabilistic Shading when mixing two Particle Shaders in Bubbles/Splashes/Cellular mode
Crash when rendering Particle Shader using Ray-traced Scattering mode and Probabilistic Shading turned on
Probabilistic volumetrics rendered particles in Point mode incorrectly when combined with Smoke
Render slowdown on machines with many cores in Bubble/Cellular/Splashes mode between V-Ray Next and V-Ray 5
Count Multiplier slowed down significantly after Phoenix 4.10
Count Multiplier above 1 created particles even between distant chunks of particles
Memory leak when rendering in Mesh mode
Artifacts in the mesh normals over liquid features which render in front of the horizon line, in Ocean or Cap Mesh mode with Horizon Roughness
Line artifacts or loss of detail with Cap Mesh mode and Ocean Мesh mode and low angled camera
Stepping artifacts in Ocean Mesh mode smoothed with Use Liquid Particles when the liquid level was much different than the ocean level
All types of Phoenix previews were drawn on top of and occluded V-Ray's Viewport IPR
Enabling "Initial Liquid Fill" in the Extra Phoenix Attributes in caused a V-Ray IPR refresh feedback loop
Crash when stopping V-Ray IPR rendering of a scene with Ocean Quick Setup preset
Crash when typing in the Clear Channels field of the Property Lister
Re-timed particles using Time Bend Controls lost their ID channel
Re-timing particles without IDs caused them to disappear in blended frames
Grid previews disappeared when switching to "Velocity" Grid Blend mode after changing the Input Play Speed to <1 while the Grid Blend mode was a different one
Grid simulation with high velocity using Adaptive Grid and Precise Tracing Grid Blend mode appeared chopped apart
Moving geometries used in a Body Force created wrong velocities with the Internal Damp or Damp Min Vel options since Phoenix 4.30
Particle Preview size did not work for some particle systems in Maya 2022
All Phoenix previews were not updated properly on scrolling the timeline when 'Smooth shade all' and 'Use default material' were both ON in Maya 2022
Viewport got stuck when using a Particle Texture as a Surface Channel for meshing
The 'Only if Selected' preview option did not work for the Velocity Streamlines
The preview did not clear if using Play Length and scrolling the timeline to an empty frame
Cache File Content time did not show leading zeroes before hours and minutes
The vertical scroll in the Log and the Cache File Content windows did not work if the text had too many lines
Rare crash when opening the Particle Preview rollout of the Phoenix Previewer
Saving an image sequence in the Standalone previewer in CLI mode was saving only the first frame
Zooming in very close on large cache files locked the camera
The GPU preview was stretched and skewed with a rotated Simulator in Maya 2022
Opening a Maya scene with a Simulator created after Phoenix 4.40 and simulating always created a particle TexUVW channel
Particles created by the simulation sometimes had invalid or repeating IDs
Тhe grid velocity from the vector "vel" channel of imported VDB caches was not the correct scale
Grid RGB channel broke when the grid size was above 1 billion voxels
AUR caches containing Particle Velocity increased in size, since Phoenix 4.40
Smoothed Velocity channel of VDB caches incorrectly had very large or very small scale
The Blood Splatter and Coffee Quick Setup presets used different VRayMtl and Particle Shader settings than the 3ds Max ones
The Honey and Beer Quick Setup presets differed from the 3ds Max ones
The Waterfall toolbar Quick Setup preset changed since Phoenix 4.30
Container Dimensions in the Simulation rollout were not correct
The 'phxfd' module could not be imported and Phoenix Python functions could not be called in Maya 2022
Simulations which started under 10 million voxels but later expanded, stopped writing to the Phoenix log file, since Phoenix 4.40
The Phoenix Previewer and Cache Converter did not install with execute permissions on Linux
