Voxel Grid - Specifies the Phoenix Simulator or V-Ray Volume Grid from where the voxel grid data will be read. Volumetric Options... – Opens the Volumetric Render settings window which contains the following rollouts: - Fire – Controls the emissive (fire) color of the Volumetric Shader, and the light emitted by the Simulator.
- Smoke Color – Controls the diffuse color of the Volumetric Shader.
- Smoke Opacity – Controls the transparency part of the Volumetric Shader.
When the Pin icon is enabled, the Volumetric Render Settings window will remain open even after deselecting the Simulator, Voxel Shader, or V-Ray Volume Grid. The option's default state is set to "Pinned", but if you need to change its behavior, you can do so from the Phoenix FD Global Preferences menu. |
Step % | rendstep – Specifies the ray marching step of the camera rays as a percentage of the cell size. As the renderer traces rays through the Simulator, this value controls how often to read information from the Grid. If this value is more than 100, some cells will start getting skipped and artifacts may appear. Usually you don't need to lower this below 90%, unless you use render curves or texture maps for the Fire or Smoke opacity or color - in these cases you might need to lower the step in order to capture the details which are smaller than a voxel, otherwise these details will either be skipped or will render very noisy. However, decreasing the step will make the render slower. Shadow Step % | rendshadstep – Specifies the ray marching step of the rays used to evaluate the lighting (shadow rays) as a percentage of the Cell Size. Usually, this value can be higher than Step %, as generally shadows will not need so much detail. Increasing the Shadow Step % will also speed up rendering performance, particularly with dome and area lights. Border Fade | borderFade – Makes the content near the Grid's boundaries more transparent to prevent sharp edges from being rendered. This parameter controls how far from the boundaries the transparent effect should start, in Scene Units. Heat Haze | heathaze, hhfactor – Traces the ray changing direction according to the gradient of the Surface channel. A value of 1 corresponds approximately to the normal heat haze in the air caused by the temperature. If smoke or another channel is selected as the source, a larger value might be necessary to achieve a visible result. A value of 0 produces no heat haze. Sampler Type | sampler – Determines the blending method between adjacent grid voxels. Used to balance between rendering speed and quality. Box – Displays voxels as cubes. There is no blending between neighbor voxels. This is the fastest mode. Linear – Linear blending occurs between neighbor voxels to smooth out the fluid's look. Sometimes this mode may unveil the grid-like structure of the fluid. Up to 20-30% faster than the Spherical option. Spherical – Uses special weight-based sampling for the smoothest looking fluid. With increasing resolution, the visual advantage of this method over the Linear method becomes less noticeable. Cutter Geometry | usegizmo, gizmo – When enabled, rendering will occur only inside the selected geometric object's volume. If Fire Lights are enabled, only those inside the cutter will be rendered. Note that the Cutter Geometry will not work when the Render as Geometry option is enabled. Invert Cutter | invgizmo – When enabled, rendering will occur only outside of the render cutter. This is not the same as a cutter with inverted geometry because any rays that do not intersect the cutter will be shaded as well. Render as Geometry | geommode – This method requires V-Ray. It produces the same result as the default Volumetric option by using procedural geometry made up from multiple transparent layers. Used when rendering Fire/Smoke for exporting deep images and Render Elements such as Normals, Velocity, Multi Matte, etc. which would not be available in default Volumetric mode. Note that enabling this option would slow down rendering. Approximate and Approximate+Shadows options for the Scattering parameter in the Smoke Color window are not supported when Render as Geometry is enabled. |
Motion Blur Mult. | mbmult – Specifies a multiplier that affects the strength of the motion blur. This value can be a negative number. Volumetric Motion Blur | vol_moblur_method – Specifies the type of Motion Blur that will be used. Ray-traced – The default Volumetric Motion Blur method. Grid-based – This method could be used instead of the default Ray-traced method in cases when you need more visible motion blur streaks, especially with faster moving fluids. The method requires a pre-pass and uses more memory. Note that the Grid-based method only affects the Volumetric, Volumetric Geometry, and Volumetric Heat Haze Modes and it doesn't apply to Mesh, Ocean Mesh, Cap Mesh, or Isosurface Modes. |
