This page provides information about the Textures rollout available under the Perf. tab when the production render is V-Ray GPU.
The Textures rollout is accessible through the Perf. tab of the Render Settings. These options give direct UI access to texture-related operations when the renderer is V-Ray GPU.
UI Path: ||Render Setup window|| > Performance tab > Textures rollout
Mode – Determines how the resolution and size of textures are handled to optimize the memory usage.
Full-size – Textures are loaded at their original size.
Resize – Adjusts the size of high-resolution textures to a smaller resolution to optimize render performance.
On-demand mip-mapped – Instead of loading all the texture files at their default resolution (original or resized), V-Ray GPU loads the textures as needed and automatically creates mip-map tiles for them (regardless of their texture type). As a result, the GPU memory consumption is decreased; textures that are not visible are not loaded, and textures that are further away from the camera are loaded with lower resolution.
Max Size Specifies the resolution to which textures are resized when Mode is set to Resize.
Format  The amount of bits per channel used to store the material texture information into memory. This does not affect textures used for lights and displacement.
8-bit – 8 bits of data used per color channel.
Half – 16 bits of data used per color channel.
Float – 32 bits of data used per color channel.
