Implemented Cloud system to the Physical Sky environment model.
Color Corrections
Implemented Filmic Tonemapper(Hable, AMPAS), Hue/Saturation and Contrast color corrections in the Post tab.
Textures
Support for animated textures(image sequences)files. Have to manually update on desired frame using Update sequence button() when not in Live Link or offline rendering.
Performance
Option for dynamic textures to reduce GPU memory usage.
Experimental option to increase FPS by decreasing sampling quality.
Option to pause rendering after reaching a certain sample level.
Overlays
Added composition grid overlays: Rule of Thirds, Central Cross, Golden Spiral, Golden Ratio and Diagonals. Available from the Composition guides overlay ()button in the top toolbar.
Modified
Output
EXR files now store camera exposure.
UX/UI
Shortcut for HQ render dialog opening. Default is Ctrl+R.
Functionality to copy the viewport to the clipboard with Ctrl+C shortcut.
Implemented sliders for Color Corrections in the Post tab.
Improved the UI responsiveness while the HQ Render setup dialog is open.
Separated Bump and Normal mapping render options.
Disabled file actions (e.g. Open Scene, Reload Scene) while in Live Link session.
Misleading error message when a scene file is corrupted.
Wrong reporting of geometry statistics in various cases (live link, deleting objects, V-Ray Proxy).
Tools
Render Animation with Chaos Vantage UI shows the correct FPS from Max.
Fixes
.vantage file
'Original camera' thumbnail not being properly displayed after loading file.
Performance
GPU memory for a VRayProxy not being freed after the proxy is deleted.
