GI – Enables GI. You can specify the number of bounces for the traced GI rays. Reflections – Enables reflections. You can specify the number of bounces for the traced reflection rays. Refractions – Enables refractions. You can specify the number of bounces for the traced refraction rays. Coat – Enables rendering of clear coat in materials. Shading graph – When disabled all materials are approximated for performance. When enabled the original, non-approximated materials are used. Bump mapping – Enables rendering of bump maps in materials. Noise threshold – Specifies the noise threshold that determines when to stop refining a pixel. Higher values allow more noise in the image, but the render is faster. Lower values help reduce the noise, but take more time to render. A value of 0.0 traces the entire image unconditionally. AdvancedOpacity maps (clip mode) – When enabled, opacity maps are rendered. Note that this option works as a clipper - it is either fully transparent or fully opaque. Option can also be accessed from the top toolbar icon(). Shading graph for glossy/GI – When disabled all materials are approximated for performance for glossy and GI rays. When enabled the original, non-approximated materials are used for glossy and GI rays. Clamp secondary rays – Suppresses the contribution of very bright secondary(GI/reflection/refraction) rays, which may typically cause excessive noise (fireflies). When enabled, the scene may turn out to be darker than the actual correct result. Min reflection glossiness – Sets minimum reflection glossiness threshold for the materials. The effect is a faster render. Bump multiplier – Specifies a global multiplier for the bump map. Active Pixels Overlay – Displays an overlay that shows the pixels that are currently being rendered. Light pixels are the ones that are still being shaded and the dark ones have reached the set noise threshold. Transparency Overlay – Displays a checkerboard pattern overlay that shows pixels with alpha < 1.0 that will not be rendered when saving a .png file with alpha. |
