Source Object – Shows the object used as a source. Reference Objects – Meshes used as a repeating pattern are added to this list. To remove a mesh from the list, select the mesh and press the Delete key. When an object is added to the list, the icon appears next to it. This determines whether the object's children are considered reference objects. It is disabled by default. Crop Box Size X/Y/Z – Sets the gizmo size along the X/Y/Z axis. Lock Crop Box Aspect Ratio – When enabled, the aspect ratio of the current Crop Box size parameters is locked. Future changes to any Crop Box size parameter cause the others to adjust, so the ratio is kept. Height % – Sets the resulting VRayEnmesh height based on the Crop box size Z. 100% means using the original crop box height. Height offset % – Sets the VRayEnmesh geometry offset along the surface normals based on the Crop box Z size. Use Polygon Selections – When enabled, only the Reference Object's selected polygons are used to create the enmesh. When disabled, the Source Object's selected polygons are used for the enmesh. Use Mesh UVW Mapping – When enabled, uses the Reference Object's mesh UVW for shading. When disabled, it uses the Source Object's UVW for shading. This option is enabled by default. Fit in Object Space – Тhe gizmo fits the position and size of the added object. |
