Particle Type – Determines whether V-Ray particles, Phoenix particles, or Geometry Instances are used. Particle Source – Specifies which emitter in the scene is used as a particle source. Supported sources are X-Particles Emitter, Thinking Particles Groups, MoGraph Matrix and Cloner objects, and Cinema 4D Emitter object. When an object is added to the list, the icons appear. The icon toggles the particle source on and off; it is enabled by default. The icon determines whether the object's children are included as particle sources. It is disabled by default.
Jump to the appropriate Particle Type page: |
