V/U/Radial VignetteThe Gradients options allow for blending gradient textures on top of the VRaySoftbox texture. A gradient vignetting can be added in the U and V direction, and also radially. On – Enables the Vignette effect. See the example below for more visual information. Flip – When enabled, the direction of the Vignette is . Gradient – Use double click on the gradient swatch to add new color mark to it or refine the current mark. A set of self-explanatory options is available from the context menu. FrameThe Frame options multiply the VRaySoftbox texture with a square shape gradient defined with the gradient swatch. On – Enables the Frame. See the example below for more visual information. Flip – When enabled, the direction of the Frame is flipped. Gradient – Use double click on the gradient swatch to add new color mark to it or refine the current mark. A set of self-explanatory options is available from the context menu. Frame Tint On – When enabled, modifies the color of the gradient. Frame Tint Color – Specifies the tint color. Frame Tint Strength – A multiplier that controls how strong the effect of the Tint Color parameter is. Frame Noise Amount – Controls how strong the Noise effect on the gradients is. Frame Noise Size – Changes the scale of the noise function. Frame Noise Phase – Controls the speed of the noise procedural animation. Fractal Noise – Enables fractal noise. Fractal Levels – Sets the levels for the fractal function. |
