This page provides information about the Light Rectangle in V-Ray for Grasshopper.
On (Boolean) – Enables or disables the light source.
Plane (Base plane) – The rectangle light base plane, where its geometry is positioned and orientated along.
Color (Color)– Provides a slot to set a light source color.
Intensity (Number) – Provides an option to control the light source intensity. Calculated in Default (Scalar) units.
Invisible (Boolean) – This option makes the light source invisible. It does not affect the light source's illuminance.
Shape (Integer) – Specifies the shape of the light object..
U/V Size (Number) – Controls the U/V size of the light measured in scene units.
Dir (Number) – Specifies the spread of the light beam. Value of 0 emits light equally in all directions. Increasing the value makes the light beam more narrow and concentrates it in one direction.
Light (Generic Data) – Light output that can be connected to a V-Ray Render node.
Rectangle Light node connection. Note the toggled off Simple Light Rig plugged used as an override. If there is no Light Rig input in the V-Ray Render component it will always internally create one.
