Basemap – The base texture that is corrected. Config Src – Manually specifies an OCIO configuration. If not specified, the OCIO environment variable is used. Auto Environment File Internal Config File – Specifies the OCIO configuration file. This option is available only when the Config Src is set to File or Auto. Inout Type – Determines how the input and output color spaces are specified: Colorspaces – The user specifies the input and output color spaces directly. Roles – The user specifies the input and output color space depending on the task that they want to perform as defined in the OCIO configuration. Mode – Specifies what color transformations to be performed: Color Space – The texture performs color space conversions. CDL Transform – The texture performs an ASC CDL transformation. CDL stands for "Color Decision List" which is a color grading information exchange format developed by the ASC (American Society of Cinematographers). File Transform – The texture performs a color transformation based on another file (i.e. .3dl, .lut, .cube etc). Log Convert – The texture performs log2lin or lin2log conversion. Display – The texture performs color space conversion for display. Look – The texture performs a Look transform. The OCIO config must define looks for this mode to work. |
