This page offers information about the V-Ray Background Render Element in Cinema 4D.
The Background Render Element stores an image of the texture used in the background behind geometry in a scene as seen from the camera. Geometry that blocks the background image renders as black.
This render element interprets only a background texture, set as Env. Matte Texture (Render Settings > V-Ray > Overrides > Environment).
Other types of manually created backgrounds, such as a plane, mapped with a texture set outside a window, will not interpreted to be a "background" for the purposes of this render element.
UI Path: ||V-Ray|| > Render Elements > Background
How to add a render element to a scene
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
