Enable Deep Output – Specifies whether to include this render element in deep images. Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default. Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible. Filtering – Applies an image filter to this channel. Derive Raw Channels – Generates data in the raw channels by combining the respective color and the filter color channels. Vfb Color Corrections – Applies the post render color adjustments made from the VFB. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. Mode – Sets what type of lighting contribution is generated in the element as follows: Direct illumination – Contains diffuse and specular information from the specified lights. Direct raw – Lighting within the VRayLightSelect element behaves as a raw render element. Direct diffuse – Lights output only their diffuse contribution and contain no specular information. Direct specular – Lights output only their specular contribution and contain no diffuse information. Full – Lights provide full output for all information available in the scene such as GI, SSS, reflection, refraction, etc. Indirect – Lights output only the indirect scene lighting. Indirect diffuse – Lights output only indirect scene lighting that originated from the diffuse contribution of the specified lights. Indirect specular – Lights output indirect scene lighting that originated from the specular contribution of the specified lights. Subsurface – Light Path Expression – Allows capturing custom light transport paths with regular expressions. Light Path Expression – Allows you to enter a Light Path Expression when the Mode is set to Light Path Expression. Light Path Expression Builder – Opens the https://lpe-builder.chaosgroup.com/ webpage, available to help you compose expressions and track exactly which ray paths they capture. Include Children – |
