Pick from scene – Allows the creation of a new proxy from an object picked from the current scene. Duplicate to Mesh – Clones the proxy to a regular mesh object. Reload from disk – Reloads a previously loaded proxy file from a disk. Proxy file – Allows the loading of a previously saved object as Corona Proxy. To load a proxy file, use the ellipsis ( ... ) button right next to the empty slot. Keep in memory – When enabled and the visualization method is set to Full Mesh, the model is always loaded into RAM, and this control is ignored. Do not flush a model from RAM between renders. It increases scene parsing speed and memory consumption when enabled. |
Units – Use this parameter to set a specific measurement unit for the proxy object. Depending on the selected unit, the object's size will be affected. Auto Kilometers Meters Centimeters Millimeters Micrometers Nanometers Miles Yards Feet Inches |
Scale – Defines the scale of a proxy object. This value is also affected by the use of Cinema 4D's scale tool in "object mode". |
Setting the Corona Proxy's units to ''Auto'' will acknowledge the project scale and adapt the object's size accordingly. |
Visualization method – These options set the viewport visualization method. Solid bounding box – Using this option displays the proxy object as a solid box. Wire bounding box – Using this option displays the proxy object as a wire box. Point cloud – Using this option displays the proxy object as a cloud made out of points. The Point Cloud visualization method is the recommended solution, as it makes it easy to see the shape of the proxy object while keeping great viewport performance. |
Full mesh – Using this option displays the entire geometry that the proxy object contains as if it wasn't a proxy object. The Full Mesh option should not be used in cases involving complex geometry, as it does not bring any viewport performance improvement compared to displaying the original geometry. |
Point cloud displayed – Defines the level of visibility for the Corona Proxy object in a viewport. The Point cloud displayed parameter is only available when the Visualization method is set to Point cloud. |
