Visible directly – When enabled, the Corona Sun is directly visible to the camera. Visible in reflections – When enabled, the Corona Sun is directly visible in reflections. Visible in refractions – When enabled, the Corona Sun is directly visible in refractions. Generate caustics – Enabling this option allows for generating caustics. Visible in editor – When disabled, this hides the object in the viewport. Apply shadows from clouds – When enabled in combination with the clouds from the Corona Sky, the sun casts shadows from the clouds. Use old (pre-v6) color mode – When enabled, the sun's realistic color is computed using the Hosek&Wilkie sky model. |
