After setting up LightMix (either automatically, or manually), the color and intensity of each light can be adjusted in the VFB. Go to the LightMix tab in the Corona VFB and change the desired parameters - this can be done during, or after rendering, for both regular and interactive rendering. You can also use additional buttons below the lights list. >Scene - This button bakes all LightMix colors and intensities into the scene lights. After clicking this and confirming, the image displayed in the VFB is temporarily changed to the non-LightMix version, and you need to re-render it to get the desired result. Instanced lights become unique in case some of them were separately altered using the LightMix. Save... / Load... - These buttons save a LightMix preset as a .conf file. This is useful, for example, when creating day and night versions of a scene. It is also possible to load a preset after a camera is changed and a different view is rendered. The .conf files can be also loaded into the Corona Image Editor. Toggle all - This button enables or disables all lights in the LightMix list. All 1.0 - This button reverts all LightMix layers' intensities to 1.0, which means the values set in the scene are used - this does NOT make all lights equally bright if they have different intensities set in the scene. All white - This button reverts the colors of all LightMix layers to pure white, which results in having the initial colors of the light objects used. You can right-click on the light names on the LightMix list in the Corona VFB to select a specific light in the scene, add that light to the current selection, or remove that light from the current selection. |
