This page provides information on the render settings available after setting Corona as the active renderer.
In order to access the Corona render settings, you must first set Corona as the active renderer:
Once Corona is selected as the active renderer it displays all its render settings in the 3ds Max Render Setup window. In addition to the native 3ds Max Common and Render Elements tabs, Corona offers its own dedicated tabs:
