As stated in the Corona Select Material UI when material count is higher than 25, more items can be accessed through MAXScript. Below is a simple guide with a few possible use cases: In the Compact Material Editor:Set number of items in the Corona Select Material in the 1st material editor slot to 100: meditMaterials[1].mtlCount = 100 |
Add a new Corona Material to the 1st slot of the Corona Select Material: meditMaterials[1].materials[1] = CoronaMtl () |
Select 5th item: meditMaterials[1].selected = 5 |
In the Slate Material Editor:Set number of items in the specific Corona Select Material (in this case called "mymaterial") to 100: rootScene[#SME][#View1][#mymaterial____CoronaSelectMtl].Properties.reference.mtlCount = 100 |
Add a new Corona Material to the 1st slot of the specific Corona Select Material: rootScene[#SME][#View1][#mymaterial____CoronaSelectMtl].Properties.reference.materials[1] = CoronaMtl () |
Select 5th item of the specific Corona Select Material: rootScene[#SME][#View1][#mymaterial____CoronaSelectMtl].Properties.reference.selected = 5 |
TroubleshootingThere is something wrong with numbering when adding and selecting materials through MAXScript! Due to a small bug in the current version of Corona, the indexes start from different numbers, so for example if you assign a material to slot 1 of the Corona Select Material it will actually be assigned to slot 0. So to select it you will need to use selected = 0, not selected = 1. How do I know what commands I should use? You can open the MAXScript Listener (Scripting > MAXScript Listener...) and enable the MacroRecorder (MacroRecorder > Enable) to record various actions you perform in the material editor (such as creating new materials, changing the number of items in the Select Material, plugging different materials into different slots, selecting specific materials, etc). This can help you find the syntax which you will need to use, specific to your scene. |
