Input – The input map which is excluded from the VFB tone mapping influence. Affect by Corona VFB Postprocessing Exposure – When enabled, the input map is affected by custom exposure. When disabled, the map is excluded from exposure influence. Tone mapping – When enabled, the input map is affected by various tone mapping operators. When disabled, the map is excluded from their influence. LUT – When enabled, the input map is affected by the currently used LUT. When disabled, the map is excluded from LUT influence. |
