This page provides information about the Corona User Property Map.
The Corona User Property Map lets you get a user-defined value from a specific object (for example an RGB color value), and then use it to control a property of a material or a texture assigned to that object.
Example uses:
  • Create one material. Assign this single material to multiple objects. Change the color of specific objects based on the values specified in their object properties
  • Create one material and control the brightness of specific objects based on their user properties
  • Blend two materials using a mask. Then control how this mask is affecting various objects by controlling the opacity of that mask based on the user properties of specific objects
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZTvMxDFKVb8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Properties
Attribute name – Specifies the name of the user property to display. It is case-sensitive.
Default (color) – Specifies default color value, substituted when no user property is found in an object.
Default (mono) – Specifies default monovalue, substituted when no user property is found in an object.
