Occluded color – Allows to choose the occluded color using a color picker or load a map. Unoccluded color – Allows to choose the unoccluded color using a color picker or load a map. Max Distance – Limits the maximum distance a ray travels before it is assumed to have left the scene. A low value makes it possible to use AO even in closed environments. Color spread – Changes how rapidly the occluded color replaces the unoccluded one when increasing the occlusion. Quality – Increases the number of samples. Higher values will render slower, but will produce clean results faster. Even low values will eventually converge to a clean image. Use legacy color spread – If enabled, the color spread will be computed as in the older versions (prior Chaos Corona version 10). However, in that case "quality" parameter will not only affect the noise but also the look of ambient occlusion. If set to false, the color spread is less prominent, but the look of ambient occlusion does not change with the "quality" parameter. Calculate from – Controls where the occlusion is sampled: Outside – Only considers occlusion above the normal (outside the object) - this typically creates occlusion by other objects nearby. Inside – Only considers occlusion below the normal (inside the object) - this typically creates occlusion on object edges. Outside + Inside – Calculates both modes at once. Ray directionality – Defines how strong the tested rays will be concentrated around the normal. With a low value, all directions are considered equally. Increasing the value causes the shader to be more dependent on whether the direction directly above the surface is occluded or not. Direction offset X/Y/Z – Offset the generated rays. This is useful e.g. when simulating wear from leaking water. Excludes – Different ways to limit the effect: No excludes – Calculates full occlusion. Use exclude list – Excludes particular selected objects. Only the same object occludes – Calculates the occlusion only using the same object, completely ignoring all neighboring objects. Only other objects occlude – The exact opposite to the previous one. |
