Pick from scene – Creates a new proxy from an object picked from the scene. Load from file – Loads a previously saved object as Corona Proxy. Viewport Display Method – Sets the viewport display method. The available options are Solid Bounding Box, Wire Bounding Box, Point Cloud, and Full Mesh. The Point Cloud is the recommended solution, as it makes it easy to see the shape of the proxy object, while keeping great viewport performance. |
The Full Mesh option should not be used in cases involving complex geometry, as it does not bring any viewport performance improvement compared to displaying the original geometry. |
Point cloud [%] – Defines a level of visibility for Corona Proxy object in a viewport. Available only when the Point Cloud method is selected. Keep in memory – Do not flush a model from RAM between renders. It increases scene parsing speed and memory consumption when enabled. When the viewport display method is set to Full Mesh, the model is always loaded into RAM and the "Keep in memory" checkbox is ignored. |
Reload from disk – Reloads a previous loaded proxy file from a disk. Batch convert – Prompts from a directory, and converts all proxies in that directory. and in its subdirectories to the latest Corona format (.cgeo). Original proxy files are preserved. Duplicate to mesh – Clones the proxy to a regular mesh object. |
