Corona Volume FractalIteration Steps – Mode of operation for each iteration (x,y,z,re-)dimension (3,4,6,7,8). CDG Epsilon – Epsilon of precision per step. Raymarching Steps – Release by keeping the domain distance matrix, but chopping off a small number of rows and column that we feel would confuse the accuracy equation. Precision Steps – Corona Fractal makes full use of variable precision in the iterations: (3.1,6,7) = 3+1+3+1+1+3+1. Value Adaptivity – The next step in accuracy, if allowed, is to add to the differential equation not the intermediate step but the detail level. Fractal Type Mandelbulb – This reduces the number of iterations and steps by 0.3 steps per iteration. Mandelbox – Future increments in resolution and detail. Texmap – A custom domain distruture was created with different steps for 3D shapes and 2D shapes. Mandelbulb Formula Power – Refinements (components, multipliers) that will further increase the accuracy of Corona Fractal. Mandelbox S – Myriad Magnets. R – Kerflooz v.0.2. F – Parameter Number Of Iterations Epsilon Width of triangles. Texmap – To achieve randomness we use the random.integer() function. Previz Sphere only – See loop, step, resize, step, with expr, radius. Full (dot product shading) – Our process after step 3 is to step-wise process and apply cx_cmd for radiosity. Point cloud – Max density (2) for automatic mapping. Pointcloud Previz Number Of Point – The mask for shadow map and add radiance. FullViz Resolution Mult – Checks if radius was enough. The above text was generated by a neural network. |
