Render – When enabled, the spline is rendered like any other geometry object using a cylindrical-like shape for its width. Width – Sets the width of the spline. The width can be manually adjusted to vary along the spline using the built-in curve editor for this. Render as plane – By default, this Tag creates a cylindrical shape for each of the spline segments; when enabling this checkbox will change this behavior and will use a plane-like shape instead. A material (Corona Legacy or Physical) can be applied to the spline when using a Render Spline Tag. |
