Lock sampling pattern – When enabled, the noise will be "locked" in place, both in still frames and animations, making it less visible. Disabling this option will produce a completely different noise pattern each frame, which is required by some third party de-noising applications (but not by the Corona denoiser). When rendering using Distributed Rendering or a render farm service, the noise might be different from frame to frame regardless of this option. Conserve memory (slower) – When enabled, Corona will consume less memory at a cost of rendering performance. This option can decrease the peak memory usage by up to 30%. Consider turning this on if you are running out of memory during rendering. Automated out-of-core textures – When enabled, Corona automatically offloads unused parts of textures to HDD to consume less memory. You can set details in the System Settings dialog. Sampling BalanceGI vs. AA balance – Number of GI samples per each anti-aliasing sample. Higher values will make global illumination and light noise clean up faster, while lower values will make the antialiasing, motion blur, and depth of field noise clean up faster. Setting this value under 2 or above 64 is not recommended. Light Samples Multiplier – Number of direct lighting samples per each GI sample. Increase this value in scenes with visible noise in direct lighting. Default value of 2.0 works well in most cases. Speed vs. Accuracy BalanceMax Sample Intensity – Maximum brightness of the secondary GI samples. This is the tradeoff between rendering performance and physical accuracy. Lower values suppress noise, but produce a darker image with lower intensity of reflections and caustics. Higher values produce brighter reflections and caustics, but also more noise in the image. Default value of 20 works well in most scenes. Value 0 is a special case that enables an unbiased mode (this mode is not production-ready as it will never clear noise in some scenes). Max ray depth – The maximum number of light bounces. Lowering this value slightly improves performance, increasing it slightly improves accuracy. However, the change in Corona is very small compared to other renderers, so keeping the default value is advised. DisplacementScreen size (px) – When selected, displacement tessellation will be performed adaptively in the screen space. This is usually a lot more efficient. Size sets the number of pixels each tessellated triangle spans in the image. Lower values will improve displacement quality at the expense of memory usage and preprocessing time. World size (units) – When selected, displacement tessellation will be performed absolutely in the world space.\r\n\r\nThis method is usually inefficient except for special cases (to prevent popping artifacts in animations). Size sets the maximum length of each tessellated triangle in world units. Lower values will improve displacement quality, at the expense of memory usage and render preprocessing time. Beware of setting this value too low and using this method on large objects, as this may consume all the available memory and result in a crash. Interactive RenderingMax passes – Limits the maximum number of passes rendered in the interactive rendering mode. When using this feature, your CPU and cooling will thank you for letting them rest. Note that for interactive render regions, this value is best left set to 0 to ensure that new or changed regions will render (otherwise they will not render if the max passes has already been reached). Force Path Tracing – When on, Path Tracing will be always used as primary and secondary solver in interactive rendering, even when UHD Cache is selected for regular rendering. This keeps the interactive rendering responsive, avoiding the cost of UHD Cache precomputation. Fast preview denoise during render – When enabled, the image will be iteratively denoised during the render. This replaces a noisy render preview with a noiseless, albeit low-quality image that gets progressively refined as render converges. It can help to get a quick estimate of overall lighting in the scene. Caustics SolverEnable – Generates physically correct caustics at the cost of lower rendering performance. Note that to render refractive caustics you need to enable them in CoronaMtl. 0 objects excluded... button – Exclude/Include list of scene objects that can receive caustics. "+" button – Adds the currently selected objects to the Caustic solver include/exclude list. Only in caustics element – When checked, caustics will be rendered only in special CShading_Caustics render element. When unchecked, caustics will appear also in beauty, light select and all other applicable render elements. Caustics from environment – If enabled, caustics solver will generate caustics from environment map lighting. This option does not influence caustics generation by sun. |
