This article explains the settings and values for the Corona Normal shader.
Controlling Scene Environment
The Corona Select Shader is used to quickly switch between 3 different HDR images.
In the following example, the Corona Select shader has been used to change the screen texture using a Corona Light Material with the "Emit light" option turned off.
