@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Official Release
Date - October 13, 2022
New Features
NVidia AI Denoiser
Option to denoise only final sampling pass in offline rendering.
Modified
Environment
Implemented a default Vantage sun so Physical Sun and Sky option is available in the Environment mode drop-down.
UX/UI
Added "Always On Top" button in the top toolbar and shortcut (Ctrl+Alt+T).
Added outlines to rollouts.
Improved the snapping behavior for manipulation gizmos.
Added sliders below parameters with soft range and CTRL(snaps to 1/1000 of the slider's soft range value), SHIFT(snaps to 1/10 of the slider's soft range value) and CTRL+SHIFT(snaps to 1/100 of the slider's soft range value) modifier keys for finer control.
Synchronized value defaults and ranges between Vantage UI and "Render animation via Live Link" dialog in 3Ds Max.
Path resolver
Improved path resolver now searches every subfolder next to the imported file, for assets.
Motion blur
Reduced artifacts from motion blur
Denoiser
Improved Vantage denoiser result in refraction and flickering object edges.
Improved refraction quality when switching between Vantage and NVidia AI in Combined denoiser mode.
Improved reflection detail with NVidia AI denoiser.
Auto-exposure
Improved auto-exposure that accumulate samples in dark areas (single GPU only).
Fixes
Rendering
Visual popping of textures with "Dynamic textures" option enabled.
Wrong blending of the sun disk with the ground albedo.
Wrong alignment of the sky texture's horizon line.
Temporal denoiser and postprocessing passes breaking with dynamic textures.
Reduce flickering being used when disabled in High quality rendering.
Auto-exposure
Crash when starting an offline render with "Auto exposure" enabled on systems with 2 GPUs.
Command line
Crash when rendering with -denoiser=0.
Live Link
Hang when the Live Link drops during a sequence rendering.
Random abort while rendering sequence using "Render animation using Chaos Vantage".
Live Link in 3ds Max doesn't start with the first click on the Start/Stop button.
Distributed rendering in 3ds Max to always deactivate when the Live Link stop button is pressed.
Motion blur
Not applying to moving objects when using "Render animation using Chaos Vantage".
Not rendering in "Render animation using Chaos Vantage" Maxscript.
Import/Load
Errors caused by loading empty string texture filenames.
Scene animation range one frame shorter when loading .vantage file.
UX/UI
UI bug when switching between 'Focal length' and 'Field of view'.
Transform manipulation and snapping windows not being disabled in Live Link.
Inconsistent spinner value changes on secondary monitor.
Wrong rotation range for transform type-ins.
Chaos Vantage starting at invalid coordinates when monitor layout changes between sessions.
Render elements
Missing velocity in EXR.
Alpha getting lost in EXR when motion blur is enabled.
