This page provides information about V-Ray for Revit Public APIs.
V-Ray for Revit Public API is a gRPC server application that allows clients to programmatically read and configure V-Ray for Revit's properties and export V-Ray Scenes.
Service Definition (public_api.proto)
V-Ray for Revit Public API provides the
public_api.proto
 file, which represents the service definition and protocol format. Alongside the .proto file, two auto-generated C# files are provided -
PublicApi.cs
 and
PublicApiGrpc.cs
. These two files contain the C# classes for all requests, responses, messages, and enums. The public_api.proto can be used to generate a binding in a language different from C# and develop a client in any of the supported languages.
service ApiServer {
rpc GetProjectName (GetProjectNameRequest) returns (GetProjectNameResponse);
rpc GetProjectChangedNotificationStream(GetProjectChangedNotificationStreamRequest) returns (stream ProjectChangedNotification);
rpc GetViews(GetViewsRequest) returns (GetViewsResponse);
rpc SelectView(SelectViewRequest) returns (SelectViewResponse);
rpc GetProperties(GetPropertiesRequest) returns (GetPropertiesResponse);
rpc GetProperty(GetPropertyRequest) returns (GetPropertyResponse);
rpc SetProperty(SetPropertyRequest) returns (SetPropertyResponse);
rpc ExportVRScene(ExportVRSceneRequest) returns (ExportVRSceneResponse);
rpc GetVRayMaterials(GetVRayMaterialsRequest) returns (GetVRayMaterialsResponse);
rpc SaveVRayMaterialToFile (SaveVRayMaterialToFileRequest) returns (SaveVRayMaterialToFileResponse);
GetProjectName
GetProjectName
 is a unary RPC that sends a single
 to the server and gets a single
 back. It is used to obtain the name of the currently active project in Revit.
message GetProjectNameRequest {
google.protobuf.Empty empty = 1;
message GetProjectNameResponse {
bool success_status = 1;
string message = 2;
string project_name = 3;
 is a server streaming RPCs where the client sends a
 to the server and gets a stream to read a sequence of
 messages back. It is used to receive a notification each time the active project in Revit changes.
message GetProjectChangedNotificationStreamRequest {
message ProjectChangedNotification {
string project_name = 1;
GetViews
GetViews
GetViewsRequest
GetViewsResponse
 back. It is used to obtain the names and unique ids of all 3D Views in the project. This information is later used when selecting a view for export.
GetViewsRequest
message GetViewsRequest {
GetViewsResponse
message GetViewsResponse {
string message = 2;
ViewMap view_map = 3;
ViewMap
message ViewMap {
map<string, View> values = 1;
View
message View {
string unique_id = 1;
string name = 2;
SelectView
SelectView
SelectViewRequest
SelectViewResponse
 back. It is used to select a view before exporting a V-Ray Scene.
SelectViewRequest
message SelectViewRequest {
GetViews
 RPC.
SelectViewResponse
message SelectViewResponse {
string message = 2;
GetProperties
GetProperties
 back. It is used to get all V-Ray properties for the active project.
message GetPropertiesRequest {
message GetPropertiesResponse {
string message = 2;
PropertyMap property_map = 3;
PropertyMap
message PropertyMap {
map<string, Property> values = 1;
Property
message Property {
string unique_name = 1;
string readable_name = 2;
string type = 3;
PropertyCategory category = 4;
PropertyValue value = 5;
PropertyCategory
enum PropertyCategory {
Global = 0;
Material = 1;
Environment = 2;
Camera = 3;
Local = 4;
Swarm = 5;
Channel = 6;
Proxy = 7;
VRayMaterial = 8;
PropertyValue
message PropertyValue {
oneof value
bool bool_value = 1;
int32 int_value = 2;
float float_value = 3;
string string_value = 4;
LightingAnalysisQuantity LightingAnalysisQuantity_value = 5;
LightingAnalysisScale LightingAnalysisScale_value = 6;
LightingAnalysisDisplay LightingAnalysisDisplay_value = 7;
DenoiserMode DenoiserMode_value = 8;
DenoiserEngine DenoiserEngine_value = 9;
DenoiserRadiusType DenoiserRadiusType_value = 10;
VRayRenderEngine VRayRenderEngine_value = 11;
VRayResolutionRatio VRayResolutionRatio_value = 12;
VRayResolutionDPIType VRayResolutionDPIType_value = 13;
VRayResolutionPrinterUnit VRayResolutionPrinterUnit_value = 14;
EnvironmentType EnvironmentType_value = 15;
ScreenPlacementType ScreenPlacementType_value = 16;
BackgroundType BackgroundType_value = 17;
VRaySceneQuality VRaySceneQuality_value = 18;
VRayImageSamplerType VRayImageSamplerType_value = 19;
VRayGIEngine VRayGIEngine_value = 20;
VRayLightEvaluation VRayLightEvaluation_value = 21;
VRayCameraMode VRayCameraMode_value = 22;
VRayCameraStereoLayout VRayCameraStereoLayout_value = 23;
VRayCameraFocusSource VRayCameraFocusSource_value = 24;
LightMixGroupBy LightMixGroupBy_value = 25;
AColor AColor_value = 26;
Color Color_value = 27;
GetProperty
GetProperty
GetPropertyRequest
GetPropertyResponse
 back. It is used to get a single V-Ray property from the active project.
GetPropertyRequest
message GetPropertyRequest {
GetPropertyResponse
message GetPropertyResponse {
string message = 2;
Property property = 3;
SetProperty
SetProperty
SetPropertyRequest
SetPropertyResponse
 back. It is used to set a single V-Ray property in the active project.
SetPropertyRequest
message SetPropertyRequest {
PropertyValue value = 2;
SetPropertyResponse
message SetPropertyResponse {
string message = 2;
ExportVRScene
ExportVRScene
 back. It is used to export a V-Ray Scene of the currently selected 3D View.
message ExportVRSceneRequest {
string export_file_path = 1;
bool export_compressed = 2;
bool export_hex_format = 3;
bool export_as_archive = 4;
message ExportVRSceneResponse {
string message = 2;
GetVRayMaterials
GetVRayMaterials
 back. It is used to obtain the names of all V-Ray materials in the project. This information is later used when saving a V-Ray material to a .vrmat file.
message GetVRayMaterialsRequest {
message GetVRayMaterialsResponse {
string message = 2;
repeated string material_names = 3;
 back. It is used to save a V-Ray material along with all of its assets to the file system. When the material is saved, a folder named
maps
 appears next to the .vrmat file. This folder contains all assets, i.e. textures, used by the material. Always keep the
maps
 folder and the .vrmat file in the same folder.
message SaveVRayMaterialToFileRequest {
string material_name = 1;
string file_path = 2;
message SaveVRayMaterialToFileResponse {
string message = 2;
Enums and custom types
enum LightingAnalysisQuantity {
LuminanceCD = 0;
IlluminanceLX = 1;
enum LightingAnalysisScale {
Linear = 0;
Logarithmic = 1;
enum LightingAnalysisDisplay {
FalseColors = 0;
GridOverlay = 1;
DenoiserMode
enum DenoiserMode {
ReplaceRGB = 0;
DoNotCalculate = 1;
GenerateChannel = 2;
DenoiserEngine
enum DenoiserEngine {
Default = 0;
NVIDIA = 1;
DenoiserRadiusType
enum DenoiserRadiusType {
CustomType = 0;
Mild = 1;
Normal = 2;
Strong = 3;
VRayRenderEngine
enum VRayRenderEngine {
CPU = 0;
GPU = 4;
RTX = 7;
VRayResolutionRatio
enum VRayResolutionRatio {
Widescreen = 0;
Screen = 1;
Square = 2;
Picture = 3;
Landscape = 4;
Portrait = 5;
CropRegion = 6;
Custom = 7;
enum VRayResolutionDPIType {
UnusedVRayResolutionDPIType = 0;
DPI75 = 75;
DPI96 = 96;
DPI150 = 150;
DPI300 = 300;
DPI600 = 600;
UnusedVRayResolutionDPIType: NEVER USE THIS VALUE. IT WAS INTRODUCED DUE TO PROTO SYNTAX LIMITATIONS.
enum VRayResolutionPrinterUnit {
Inches = 0;
Millimeters = 1;
EnvironmentType
enum EnvironmentType {
Sun = 0;
Dome = 1;
None = 2;
ScreenPlacementType
enum ScreenPlacementType {
ScreenPlacement = 0;
SphericalPlacement = 1;
BackgroundType
enum BackgroundType {
NoBackground = 0;
CustomBackground = 1;
RevitBackground = 2;
VRaySceneQuality
enum VRaySceneQuality {
Draft = 0;
Low = 1;
Medium = 2;
High = 3;
VeryHigh = 4;
enum VRayImageSamplerType  {
UnusedVRayImageSamplerType = 0;
Buckets = 1;
Progressive = 3;
VRayGIEngine
enum VRayGIEngine {
IrradianceMap = 0;
BruteForce = 2;
LightCache = 3;
VRayLightEvaluation
enum VRayLightEvaluation {
Full = 0;
Adaptive = 2;
VRayCameraMode
enum VRayCameraMode {
Standard = 0;
Orthogonal = 7;
SphericalPanorama = 9;
Cube = 10;
enum VRayCameraStereoLayout {
UnusedVRayCameraStereoLayout = 0;
SideBySide = 1;
TopBottom = 2;
enum VRayCameraFocusSource {
FixedDistance = 0;
FixedPoint = 2;
AColor
message AColor {
float r = 1;
float g = 2;
float b = 3;
float alpha = 4;
Color
message Color {
float r = 1;
float g = 2;
float b = 3;
Code Samples (C#)
Obtaining the Server Port
In order to connect to the Public API Server, the client needs to know which port the server is running on. When the the V-Ray for Revit Public API Server starts, it chooses a random free port to start on and writes this information in the
C:\Users\%USERPROFILE%\AppData\Roaming\Chaos Group\V-Ray for Revit 20XX\config.json
, where
XX
 is the Revit version. When your code is running from within a Revit Addin, use the current process id (i.e. of Revit.exe) to locate the V-Ray for Revit API Server running in the same instance of Revit.exe. When your code is running from a standalone application (console app, WPF app, etc.) and there is more than one instance of the same Revit.exe version running, it is up to you to decide to which instance of V-Ray for Revit API Server to connect to.
Here is how the
apiServers
 entry might look like in config.json:
"apiServers": [
"PID": 22920,
"port": 58538
"PID": 14792,
"port": 58611
And here is how you can obtain the port, depending on whether your code is executing from within a Revit Addin or from standalone application:
private const int RevitVersion = 2020;
private static readonly string ConfigJsonPath = Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData),
$"Chaos Group\\V-Ray for Revit {RevitVersion}", "config.json");
private static int GetServerPort()
var runningInRevitAddon = true;
using (var reader = new StreamReader(ConfigJsonPath))
var json = JObject.Parse(reader.ReadToEnd());
var apiServers = json["apiServers"] as JArray;
if (apiServers != null && apiServers.Count > 0)
JObject apiServer;
if (runningInRevitAddon)
apiServer = apiServers.OfType<JObject>().SingleOrDefault(jo => (int)jo["PID"] == Process.GetCurrentProcess().Id);
else
apiServer = apiServers.OfType<JObject>().FirstOrDefault();
if (apiServer != null)
return (int)apiServer["port"];
return -1;
When the Public API Server is shutdown, i.e. the user closes Revit, its entry is deleted from
config.json
Note that the code above uses the Newtonsoft Json.NET library, but you can read the json file in any way that you prefer.
Connecting to the Server
public async Task<bool> ConnectAsync()
var serverPort = GetServerPort();
if (serverPort != -1)
this.channel = new Channel($"localhost:{serverPort}", ChannelCredentials.Insecure);
var deadline = DateTime.UtcNow.AddSeconds(1);
try
await this.channel.ConnectAsync(deadline);
return true;
catch (TaskCanceledException)
return false;
else
Debug.WriteLine("Public API Server has not started yet!");
return false;
GetServerPort
is from the previous code snippet.
Get the active project name
public async Task<string> GetProjectNameAsync()
try
var client = new ApiServerClient(this.channel);
var response = await client.GetProjectNameAsync(new GetProjectNameRequest());
if (response.SuccessStatus)
return response.ProjectName;
else
MessageBox.Show(response.Message, "Error", MessageBoxButton.OK, MessageBoxImage.Error);
return string.Empty;
catch (RpcException e)
Debug.WriteLine(e);
ApiServerClient
, and
 are all classes auto-generated by the proto-buffer compiler.
Get all 3D Views from the active project
public async Task<IEnumerable<View>> GetViewsAsync()
try
var response = await client.GetViewsAsync(new GetViewsRequest());
return response.ViewMap.Values.Values;
else
return Enumerable.Empty<View>();
Debug.WriteLine(e);
ApiServerClient
GetViewsRequest
, and
GetViewsResponse
Select a 3D View
public async Task<bool> SelectViewAsync(string uniqueId)
try
var response = await client.SelectViewAsync(new SelectViewRequest() { UniqueId = uniqueId });
return true;
else
return false;
Debug.WriteLine(e);
return false;
uniqueId
 is one of the unique ids of the views retrieved in the previous code snippet.
Get all properties
public async Task<IEnumerable<Property>> GetPropertiesAsync()
try
var response = await client.GetPropertiesAsync(new GetPropertiesRequest());
return response.PropertyMap.Values.Values;
else
return Enumerable.Empty<Property>();
Debug.WriteLine(e);
ApiServerClient
, and
Get a single property
public async Task<Property> GetPropertyAsync(string uniqueName)
try
var response = await client.GetPropertyAsync(new GetPropertyRequest() { UniqueName = uniqueName });
return response.Property;
else
return null;
Debug.WriteLine(e);
return null;
uniqueName
is one of the unique names of the properties retrieved in the previous code snippet.
Set property
 public async Task<bool> SetPropertyAsync(string uniqueName, PropertyValue propertyValue)
try
var request = new SetPropertyRequest()
UniqueName = uniqueName,
Value = propertyValue
var response = await client.SetPropertyAsync(request);
return true;
else
return false;
Debug.WriteLine(e);
return false;
uniqueName
Get all properties
 code snippet.
propertyValue
 is a
PropertyValue
 initialized with the correct type of value, based on the property type. The 7 code snippets below use the method defined in this code snippet.
Set bool property
var uniqueName = "GlobalArtificialLightsEnabled";
var propertyValue = new PropertyValue() { BoolValue = true };
SetPropertyAsync(uniqueName, propertyValue);
Set int property
var uniqueName = "customResolutionWidth";
var propertyValue = new PropertyValue() { IntValue = 800 };
Set float property
var uniqueName = "GlobalArtificialLightsIntensity";
var propertyValue = new PropertyValue() { FloatValue = 2.0f };
Set string property
var uniqueName = "backgroundImagePath";
var propertyValue = new PropertyValue() { StringValue = "C:\myimage.png" };
Set enum property
var uniqueName = "environmentType";
var propertyValue = new PropertyValue() { EnvironmentTypeValue = EnvironmentType.Dome };
Set AColor property
var uniqueName = "EnvFogColor";
var propertyValue = new PropertyValue() { AColorValue = new AColor() { R = 0.5f, G = 0.5f, B = 0.5f, Alpha = 1.0f } };
Set Color property
var uniqueName = "SunFilterColor";
var propertyValue = new PropertyValue() { ColorValue = new Color() { R = 0.5f, G = 0.5f, B = 0.5f } };
Export V-Ray Scene
public async Task<Tuple<bool, string>> ExportVRSceneAsync(string exportFilePath, bool exportAsArchive, bool exportCompressed, bool exportHexFormat)
try
try
var response = await client.ExportVRSceneAsync(new ExportVRSceneRequest()
ExportFilePath = exportFilePath,
ExportAsArchive = exportAsArchive,
ExportCompressed = exportCompressed,
ExportHexFormat = exportHexFormat
// If the export was successfull, response.Message will contain the
// actual file path of the exported V-Ray Scene
return new Tuple<bool, string>(response.SuccessStatus, response.Message);
catch (TaskCanceledException e)
Debug.WriteLine(e);
return new Tuple<bool, string>(false, e.ToString());
Debug.WriteLine(e);
await this.ShutdownAsync();
ApiServerClient
, and
Get all V-Ray Material Names
public async Task<IEnumerable<string>> GetVRayMaterialsAsync()
try
var response = await client.GetVRayMaterialsAsync(new GetVRayMaterialsRequest());
return response.MaterialNames;
else
return Enumerable.Empty<string>();
Debug.WriteLine(e);
ApiServerClient
, and
Save V-Ray Material to File
public async Task<Tuple<bool, string>> SaveVRayMaterialToFileAsync(string materialName, string filePath)
try
try
var response = await client.SaveVRayMaterialToFileAsync(new SaveVRayMaterialToFileRequest()
MaterialName = materialName,
FilePath = filePath
Debug.WriteLine(e);
Debug.WriteLine(e);
ApiServerClient
, and
Listen for project changed
public async void ListenForProjectChangedAsync()
try
using (var call = client.GetProjectChangedNotificationStream(new GetProjectChangedNotificationStreamRequest(), null, null, this.cts.Token))
while (await call.ResponseStream.MoveNext())
var projectName = call.ResponseStream.Current.ProjectName;
Debug.WriteLine("Project has changed to " + projectName);
Debug.WriteLine(e);
Resources
V-Ray for Revit Public API Client Reference Implementation
After you install V-Ray for Revit, you can find a reference implementation of a C# client at the following location: C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit\PublicAPIClient.zip. Unzip the archive somewhere on your machine and explore the Visual Studio solution. Most of the code snippets above are taken directly from this sample application. The sample application is just a reference implementation and is provided as is.
