Curve – The Bezier curve which can be manipulated by adding/removing points.
Num Bezier Points for Curve – Specifies the number of precisely calculated points from the Bezier curve. Extrapolate Beyond End Points for Curve – When enabled, it extrapolates the value beyond the control points. Extrapolate Type for Curve – Specifies the type of extrapolation for points out of the control range. You can choose between End Tangent, Linear and Constant. Clamp – Determines whether to force the result into the [0..1] clamping range. Clamp Min Value – Specifies the lower clamp limit if Clamp is enabled. Clamp Max Value – Specifies the upper clamp limit if Clamp is enabled. CPU Curve Mode – Specifies the GPU curve mode. You can chose between Intensity, Red, Green, Blue, Alpha. |
