This page describes how to set up your local system so that it loads the files for the correct version.
Installing V-Ray for Houdini from a .zip file provides several advantages over the regular installer:
It's recommended that you make sure your computer meets the System Requirements for running Houdini with V-Ray before installing V-Ray.
Under the hood, the V-Ray installation relies on the Houdini 3-rd party plugins package system. Houdini's packages are .json files that specify the location of custom modules. For more information, please refer to the documentation on the SideFX website. The "vray_for_houdini.json" package that is used to load V-Ray when Houdini is started is placed under "$HFS/packages" (e.g. "C:\Program Files\Side Effects Software\Houdini ##.#.###\packages" for Windows) when running the installer. You may set things up differently depending on your studio pipeline. By default, when using the installer, the location of V-Ray itself is "C:\Program Files\Chaos Group\V-Ray". Just as with the "vray_for_houdini.json", V-Ray itself can be placed anywhere on disk. As long as the "INSTALL_ROOT" variable in the json file points to a valid location, Houdini should be able to find the required modules to load V-Ray. |
Note that the EULA is accepted only for new major versions during installation from zip. |
{ "env": [ { "INSTALL_ROOT" : "C:/Program Files/Chaos Group/V-Ray/Houdini 19.0.383" }, { "VRAY_APPSDK" : "${INSTALL_ROOT}/appsdk" }, { "VRAY_OSL_PATH" : "${INSTALL_ROOT}/appsdk/bin" }, { "VRAY_UI_DS_PATH" : "${INSTALL_ROOT}/ui" }, { "VFH_HOME" : "${INSTALL_ROOT}/vfh_home" }, { "PATH" : [ "${HFS}/bin", "${VRAY_APPSDK}/bin", "${VFH_HOME}/bin" ]}, { "VFH_DSO_PATH" : { "houdini_python == 'python2'": "${VFH_HOME}/dso_py2", "houdini_python == 'python3'": "${VFH_HOME}/dso_py3" }}, { "PYTHONPATH" : [ { "method": "append", "houdini_python == 'python2'": "${VRAY_APPSDK}/python27" }, { "method": "append", "houdini_python == 'python3'": "${VRAY_APPSDK}/python37" } ]}, { "VFU_PLUGINS" : "${VFH_DSO_PATH}/usd_plugins/hdVRay/plugins" }, { "VFH_ASSET_PATH" : "C:/Users/USER/Documents/V-Ray Material Library/assets" }, { "HOUDINI_DSO_PATH" : "${VFH_DSO_PATH}" }, { "HOUDINI_GALLERY_PATH": [ { "method": "append", "value": "${VFH_HOME}/gallery" } ]} ], "path" : [ "${VFH_HOME}" ] } |
To deploy V-Ray using the ZIP archive instead of the installer, follow these steps:
In Linux or macOS environment, the process is exactly the same.
For macOS: Note that the "packages" folder resides in Applications > Houdini > Houdini 18.5.### > Frameworks > Houdini.framework > Versions > 18.5 > Resources > packages > ...
For detailed information on how to run V-Ray for Houdini, see the QuickStart Guides Introduction tutorial.
