The instructions on this page guide you through the process of setting up a simulation of water pouring on a cosmetic bottle that generates many of liquid splashes. We also take advantage of the new VoxelShader helper to create whitewater in the liquid. This simulation requires at least Phoenix 5.0 and V-Ray 5, Update 2.3. The scene can be rendered in both V-Ray 5 and V-Ray 6, but due to some differences between the two versions, some of the materials will render slightly different. To achieve the exact same end result as in the tutorial, you will need to use V-Ray 6. You can download your desired Phoenix and V-Ray versions from the downloads page. If you notice a major difference between the results shown here and the behavior of your setup, please reach us using the Support Form. The Download button provides you with an archive containing the scene files. |
