Once you turn the Finite mode on, you can immediately see that the light has its own size and relative position. Make sure the dome light is big enough.
At any point, you can make more precise adjustments using the height, radius and ground blend values. These options will help a lot with blending the environment into the scene and they should be adjusted based on your HDRi.
